What is this coolant hose called?
If you get one from toyota its much easier to replace. The ones at the auto parts store are slightly smaller than toyota making them a pain to get on.
AcIdBuRn02ZTS
227
Indiana
That little sob cost me a head gasket a few weeks back! I found a hose the right size with the right bend at a parts house and swapped them out... was a headache though as hvyman said... just a bit smaller then stock so it was a PITA to get in place.
SupraFreak619
45
Hemet, CA
I will definitely go through toyota! I was thinking of ordering one at autozone but thanks for for the enlightenment and part numbers lol I had done a HG job last year and hopefully this little turd didn't cost me another HG :/
zman6127
ZMAN
Dec 30, 2008
91
Fort Wayne, IN
Why you guys say pita. I did mine and didn't think it was so hard. Or is it cause it goes out on you and hard to see?
Zach "zman6127" Prindle
Busted_Knuckles
28
Atlanta
Hard to get to. I wound up using a 1/4" socket wrench with an extension to tighten the clamp.
There are also two 90-deg PITAs at the thermostat housing too. But, I found that pulling the distributor helps BIG TIME.
