What is the worst mistake you have ever done to your supra?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
yeah whatd you do?
worst thing i did - put diesel in the tank and then ran it til empty (and you know how hard diesels are to start when run out of gas) :D j/k
supraguru05
Dec 16, 2005
737
louisville ky
put a 7m in it :biglaugh:
no seriously worst thing i did was have it painted at a 700 dollar paint job place and use a autozone head gasket when i rebuild my 7mge 3 years ago. i had to redo the head gasket in the car with 1000 miles on the engine
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
noah89t said:
what did you do that was so bad?
I somehow... Yes "somehow" picked up a m12-1.5 tap rather the M12-1.25 tap that I originally had.............
Ran all 14 holes on the block with M12-1.5 tap....... Not repairable. Good bye block. So Now I am sitting in my room wondering how the darn I am going to get this car running by new years. I can't even afford an engine hoist thanks to the headgasket and arp stud price..
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Ummm I did not tighten the flywheel bolts down with a good tq wrench and neglected lock-tight..... i used a P.O.S tq wrench that was old and falling part. My flywheel came loose and destroyed my bellhousing at 15mph
Loki
The Future is Unwritten
Prince George, B.C.
Jeff Lange said:
Didn't put the 89+ subframe braces in when I had the subframe out. Lost one, and now my subframe is cracked. Gay.
What about the time you crashed it? or when you smashed up John's car? Jeff = fail at Supra's.
supraguru05
Dec 16, 2005
737
louisville ky
not trying to down you but didnt you notice it took quite some effort to run the tap thru just to clean the threads.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I bought it.....J/k
Probably when I didn't make sure that the fan shroud was secured on there properly. It wasn't and the fan hit it and ended up tearing the fan shroud up and put a hole in my radiator.
Oooor....Buying a soarer engine and not getting a JZA70 clip from Driftmotion. Lesson learned.
Datsrboi
Jul 31, 2007
797
Haltom Texas
supraguru05 said:
Ran all 14 holes on the block with M12-1.5 tapQUOTE]
Honestly there was not much effort at all.......... That is what bothered me. Its like as if the block was more aluminum the iron. Some SMALL resistance but not like what I am use to feeling at work. Plus I was not thinking about it too much since it did go in quite a bit before that resistance hit in.
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
Not my mistake, but worth noting
I bought an NA with a "blown" head gasket that the guy had just recently replaced but still spewed oil and water. When I pulled the head I found he had put the gasket on BACKWARDS!
