what is the best thing to use to seal my oilpan?
what should i use to seal my oil oan?
  • Toyota FIPG
    Votes: 26 68.4%
  • FIPG like material (Permatex etc)
    Votes: 10 26.3%
  • Cork (no not really just seeing who reads the TSRM).
    Votes: 2 5.3%
  • Total voters
chefma70
404
Florida
i got the full gasket set from dm.it included a cork oilpan gasket.i made myself 2 options
Edit: Edit the poll and reset the votes. Lets try this again. :)
any gasket set will come with the cork oil pan gasket except from toyota. use fipg period....
Tire Shredder
569
Oshawa
jdub;1353363 said:
Permatex The Right Stuff has served me well...don't use the cork gasket.
+1 for this stuff. It's worth the extra money.
the engine can go inter service immediatley and it has very strong adhesive properties. It is not easy to remove like RTV. It dries like a very dense rubber.
Like Jdub, it's served me well too.
do NOT use the cork gasket in any form in my opinion,even with FIPG... instead of just two sealing surfaces, (between block and pan) you'll have four. (block to gasket, gasket to block). you're actually doubling the amount of places where the FIPG must confirm and adhere to. In turn, this doubles the potential failure points.
figgie
Twin Cities, Minnesot-ah
closing this down,
TSRM says nothing about CORK anything. FIPG. So this poll is asking should I follow the TSRM or not............ and you know what they say about leading a horse to water.
Now with that said, I had closed the thread but re-opening it again.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
IJ.;1353362 said:
3bond 1207b>everything else I've tried.
Suzuki 1207b.
:D
chefma70
404
Florida
Zumtizzle;1353453 said:
Suzuki 1207b.
:D
ooooo 04suzuki gsxr 600:hitit:
im gona use my fipg .but as soon as i run out(quick) i goin straight to the suzuki dealer ship and pickin up 2 tubes of that stuff. and possible test ride one of the gsxrs
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Considering i had to literally pry my oil pan off the bottom of the block when i pulled my engine for the second time i wouldn't use anything other then toyota fipg or equivalent.
dumbo
1,913
Albera, Too Far North
I'd say the MOST important thing is to make sure the oil pan flange is flat and true. Followed by proper torque on the nuts/bolts so you don't squeeze out your gasket. Myself I used Loctite Instant gasket, comes in an aerosol can, pretty nifty.
