what is pps, turbo A, and group A ?!?
dav_dman
old guy
Oct 23, 2005
107
louisville KY/so.IN metro area
" '86.5-'92 MA70 N/A MKIIIs with Sport Package (TEMS & headlight washers on '86.5 - '88 : TEMS & PPS on '89-'92) have a 4.30, clutch-pack LSD differential. " - Doc Jonez
What is PPS? i dont know if my 90 has sport package or not. I thought everyone had TEMS in 90.
What is Turbo A?
What is Group A?
thank you,
Dave
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Turbo A was a race speced street car
Group A was the race car.
A quick search on google should give you the answers.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
FTW= For the win. If you are turbo you have 3.73. if you are na you have 4.30. pps makes the steering tighter at high speeds i think.
shaeff
Kurt is FTMFW x2!!!!
11
Around
www.mkiiitech.com - the info has been there for a long ass time, along with much, much more information that you, and EVERYONE should read through. (yes, ALL of it;))
-shaeff
ChadMKIII
Yup, Thats The G/F
Jul 14, 2006
369
Bay Area, Ca
If I read it right PPS turns down the power of/disables the power steering pump while at higher speed to keep it from robbing horse power from the engine.
That correct Jeff?
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
-shaeff
Now, why would we do that when we could just bug ya into telling us the cliff notes version????? :naughty: :biglaugh:
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
That correct Jeff?
I don't think it turns it down to reduce horsepower robing, it just makes the same amount of movement in the steering wheel translate into less movement in the wheels. If someone jolts the steering wheel at high speeds, there is less of a chance that they will slide it sideways. It also proves for more comfortable high way driving.
Edit: it "progressively" controls the effect of the steering based on speed (the faster you go, the less it will turn the wheels).
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
It can't change how far the wheels move based on how far you move the steering wheel, since the ratio remains the same, that is entirely mechanical inside the rack and pinion. Nothing you could do electronically in most R&P setups would change ratio. All it does is reduce the amount of power steering assistance.
Basically it makes the car harder to steer at higher speeds, mainly so that the steering doesn't feel over-assisted.
