what HG thickness
maitai69691
280
hilo hawaii
i did alot of searching dont understand how to do the measurments to find out what thickness HG i need. The head was decked .009 and block was .0010 Do i just add the numbers to what the stock gasket thickness...any help would be grate
bioskyline
1,236
powell river bc
3) Stock block = 198.5mm from deck to main bearing saddle
stick tape measue in the bore and measure to the top of the main bearing.
---------- Post added at 03:06 AM ---------- Previous post was at 03:01 AM ----------
you have only removed 0.01 of material, or 0.254mm. so stock hg + 0.254mm
maitai69691
280
hilo hawaii
thanks for the info i added it up and get 1.624mm but im still going to measure the block just to make sure...so ill probly be going wiht a 1.5mm HG un less theres a 1.6mm HG out there
northwestsupra
1,166
Washington, Marysville
CyFi6;1670490 said:
Good luck measuring into the thousandths with a tape measure, you might want to use something a little more precise.
Your right a yard stick. What was he thinking lol. :) << SARCASTIC REMARK DON'T USE YARD STICK
Big set of dial calipers ftw
BETTER RECOMMENDATION BELOW ME
Tape measure,yardstick WTF drugs are you guys on...........
I use a Digital Vernier, if you don't have access to precision measuring equipment err on the side of caution and go the next size up HG, 2mm is usually a safe bet and it's NOT going to make any measurable difference in performance.
northwestsupra
1,166
I said yard stick sarcastically. But you don't understand that obviously :)
Sent from my Droid using Tapatalk
maitai69691;1671756 said:
thanks IJ for the info after being on here for a cpl years you learn who to lissen to the right people
Very welcome Dude!
The 2mm is usually the safe bet if not sure of dimensions and won't hurt off boost performance, I used to run a 3mm on a new head and block and that's noticable, a real dog off boost.
