What do i need to tell mufflershop about turbo piping
grimace65
31
so cal
what kind of pipes should i get from the turbo to intercooler? etc. etc. im installing the t88h with spearco intercooler, what size pipes?all the info.
ndnxtc
Super Ultra Mega Member
Apr 4, 2005
9
Dallas, TX
No offense, but I'm not sure if you'll want to install a T88H if you don't know what kind of piping you need...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Because running a T88 requires a LOT of changes to your car, the least of which is the size of intercooler piping you are going to run. If you don't already know enough to figure out what size pipe to use, how can you possibly know what intercooler you need, how bif your injectors must be, what kind of computer you will need to run it, what wideband sensor to purchase, how big of a line you will need to run from the fuel tank, how many fuel pumps you will need, what pistons, valves, cams, and so on.
Hope that helps.
Idealsupra
Orlando
www.tampabaysupras.com
Hope that helps.
unfortunetly...it wont... :momaru:
