What do i need... [simple question]
SimpleIcon
Brigadier General
supra90turbo said:
Search the local vendor's online stores for Wideband O2 kits.
Hmm Local Vendors. The only local vendors around here are Tennessee Speed Sport... I dought they would have one.
Still my questions; Would I need another device, such as a air/fuel controler?.. or would the wideband work with the ECU? (seems unlikely)
The only real mods im worried about(at this point) is my 2mm MLS-HG and over boost. I would really like to *KNOW* if I am running lean or rich and have always thought those "light-show" a/f meters were only.... well, a light show.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Horsepowerfreaks sells them, MVP sells them, Titan sells them, 935motorsports sells them... Lots of companies sell widebands...
A wideband doesnt work with your ecu, a wideband works like an oxygen sensor, it reads the a/f ratio in your exhaust and gives you a read out... They sell A/F guages, however, that's what's considered a shortband, and its practically worthless... Its great for dancing lights, but not for a true reading...
The air fuel controller, like an SAFC, has nothing to do with a wideband...
hth...
Jake
SimpleIcon
Brigadier General
hth...
Jake
Thanks Jake, That really helps alot! I suppose the wide band kit will explain more... The thing I'm still tryin to wrap my brain around is: How can the wideband do anything if it is not hooked to the computer or a readout?? And if its just a readout- how is it tuned without a piggy-back or stand-alone?
aye mate
Hiatus over.
Maryland
Idealsupra was doing a group buy on AEM widebands. I think he only had like 12 units though, might want to check it out in the GB section.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
It's just a meter to tell you how lean or rich you are. You need to adjust your fuel with other devices, stand alone, afc, emanage, etc so that you will not be too lean or too rich.
supra90turbo
shaeff is FTMFW!
MA, 01440
Or narrowband.... :poon:
Yea, sorry SimpleIcon, by "Local Vendors" I meant local to the board... I should have been more clear. Any of the vendors that Reign Maker mentioned is a good place to check.
Also, as mentioned, a wideband o2 simply monitors air/fuel ratio, and does not, in any way, work in conjunction with your ECU. Just have a bung welded in your downpipe before any cat's and watch how pig rich you run!
Good luck!
SimpleIcon
Brigadier General
Good luck!
Thanks supra90turbo
Thanks Everyone. Its all clear now!
Dziuggy
eurotrash
san francisco, ca
dziuggy.com
next tim mod will tell me chill i will tell them to go f**k them selves.
we have way to many noob ricers going around here lately.
go read about.com on how engine works then come here use search button and then ask the questions
SimpleIcon
Brigadier General
Hmm, that doesnt even deserve a comment. Any Moderator want to get rid of this getto-sounding troll?
N
NDBoost
Guest
my flaming comments shall be with held from both of you guys.
Get a wideband kit get an S-AFC, OR get a S-AFC and jump on a dyno :)
supra90turbo
shaeff is FTMFW!
MA, 01440
SimpleIcon: if you read this, you're gonna just have to install it and monitor it. there's no way for us to tell you anything about your engine. just do it and find out for yourself. then if it's too far out for your liking, you're gonna have to buy an safc and tune it to where it's more optimal.
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
on the wideband monitoring setup.how quick are they to detect? like isit instantaneous or a slight delay? Im assuming you screw it into the dump pipe (wideband 02 sensor)
