what crank should I use?
tig321
151
Edmonton/Victoria
I'm sure there have been in depth discussions about this but I have searched and i'm having trouble coming up with anything. more than just
6m= not as smooth, +250rmp redline
7m= smoother, lower redline
I have a 7m crank from my 90 turbo but it's quite scored. Def needs machining. I also have a 6m crank from a jdm engine I can't use cause of a cracked block. this crank looks mint. I'm having the 90 engine rebuilt with forged pistons(ross most likely) Then balanced. My eventual plans are a gt series turbo and to hopefully break 400 rwhp. Does it really matter what crank I use?
Thanks
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i find that peopel use the 6m crank more then the 7m
cause it genaly lighter and stroung eghough
The redline is lower because of the ECU it's nothing to do with the Crank itself I routinely ran mine to 7700+.
I put my 6M crank back in and it's noticably harsher and if I had a choice I'd go 7M everytime.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Agreed! The 7M crank is better balanced from the factory...I used a 6M crank (had it fully balanced) and got the same results as IJ.
Supra
304
Rockford, IL
One more on IJ/JDUB's side - 7M all the way! It takes away so much more vibration. My 87T rides like a Cressida, moves like a 4th gen Supra, burns coolant like a 3rd gen. :icon_bigg
8,873
Which to use...the upgraded crankshaft. Toyota went to a crank with smaller but better distributed counter weights.
If you can.
Justin727
T-virus infected
Although there are technical reasons why they changed crank shafts in the end it comes down to personal prefference.
I have never seen a 6m nor 7m crank fail just yet. So until one does agian its just what YOU want. I stuck with the 6m crank!
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i've got a 6m, not by choice... just curious though, anyone know if the 7m cranks were ever sold in japan, seems to me, the 7m was not sold any longer when the 1jz came out, and this switch was the same time they started to produce 7m cranks for us (in the states)
edit: also, no harshness noted, in fact my car drive MUCH smoother than any other car i've driven (i've driven a LOT of cars)
Supra
304
Rockford, IL
It's not a valid comparision to drive an 1987 and then go drive a 1992 model. There's 5 years of wear and tear + the early model has hard rubber motor mounts verses the later model fluid motor mounts. There's alot of variables beyond the crank there that will transfer vibration to the driver.
As I said before, I've driven my 1987 with the 6M crank for 6+ years with various builds. This year I switched to a 7M crank and I can tell you that without ANY OTHER changes to the same car / motor, there is a significant differance between the 7M and 6M crank in terms of vibration. The 7M is much smoother over all.
