What are the advantages of running an External WG rather than Internal WG??
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
What's going on guys? I was wondering what are the advantages of running an Externally Wastegated turbo rather than an Interanlly Wastegated? I'm running a Frank 5 Greddy TD06-20g and was just wondering if I'd gain anything running a 40mm HKS Wastegate with Dump Tube? Any thoughts or responses are greatly appreciated. Thanks a lot guys.
Mo
All depends on what Turbo and Trim you're trying to control!
If you had something with a big compressor section and a tight AR you might not get enough flow from an internal gate to control it so with an external you could change to a bigger gate.
Having said this ATP have just released .63 and .82 ar Internal gate housings for the GT 35's when all that used to be available was 1.06!
tsuper92
supra addict
Apr 7, 2005
1,376
mass
other then scaring small children and fellow motorist's,drawing attention from the boy's in blue,keeping some heat out of the exhaust maybe
oh shit just re-read the post again.i was thinking re-circulated external to a dump
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Personally Id go external, I love the sound, and it scares all the little 16 yos in hondas around here, they hear the sound and are like oooo hes fast, HAHAHA. I dont have a turbo :-( but its what I WOULD get.
Mo87NA
8
Upstate NY
Alright. Now I plan on running around 25 psi on the dyno (with race gas of course). What spring would I need? Sorry if it's a dumb question. Just trying to gain some knowledge.
Mo
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Hey, thats why were here, if we know well answer. Im not sure honestly, Im not a turbo guy, just wanted to say its GOOD to ask to gain knowledge, just be sure to give back if you ever can.
X-man
member
Dec 5, 2005
309
Pulaski,Va
depends on what you want your base boost or off boost controller boost psi to be. If you are running an electronic boost controller you can effectively double the boost psi rating of the spring. I had a 10.2 psi spring in my 40 mm HKS gate and ran 7 to 8 psi on just the wastegate and 29 psi holding until redline on my HKS EVC EZ.
X-man
member
Dec 5, 2005
309
Pulaski,Va
It really adds a board range of tuning to a part that can be a pain in the butt to change being the wastegate spring when you have that much adjustablity at your finger tips. And the award of "run on sentence of the thread goes to!" Thank you,thank you.
Sean
Mo87NA
8
Upstate NY
Haha thanks for the responses guys. So a standard 40mm HKS WG with a 14 psi spring would be fine for me since i'll be running around 15-18 psi on the street and 25 psi hopefully on the dyno?
Mo
X-man
member
Dec 5, 2005
309
Pulaski,Va
Yes, because it will open alittle sooner than 14 or 15 psi on just wastegate so you could still dial it down alittle if you wanted to.
Mo87NA
8
Upstate NY
Thanks X. I appreciate the help. Last and final step will be trying to source a cheap set of cams and shims (not likely)!
Mo
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
i look it this way: IJ uses internal and he pushes more than I will :biglaugh: so maybe it's not so bad? I mean sure you won't get that sound, but who cares, you don't need to buy a wastegate that costs hundreds of dollars, and it'll free up some space down there too just for kicks, maybe make it easier to reach something in the future or w/e.
eric
Mo87NA
8
Upstate NY
I agree stretch. I may be able to pick one up faily cheap thats why I as asking. Rather than having a block-off plate made for my ebay manifold, I just thought I'd pick one up and enjoy it.
Mo
