What 550cc Injector Choices Are Recommended?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Hi guys! I hear of different people running different brand injectors. With all the choices out there, what are y'all running and had the best luck with? I know to stay away from Venoms! :icon_bigg
Secondly, is it a good idea to run 550's from older cars. Like Mazda's 550 version(s). What older injectors work with our cars and are there any compatibility or known issues doing that?
Thanks for your thoughts...
figgie
Twin Cities, Minnesot-ah
Well
most import cars from Japan run Denso. So those RX-7 injectors are denso.
Imports from Europe run Bosch.
Delphi/Lucas/Rochester are in most american cars.
After that, the RC and PTE are rebadged of the ones I just mentioned just that they are flow tested (some companies might, some other might not). ;)
83restomod
Bryan
Feb 11, 2008
100
clinton NJ
i know im reving an older thread and ppl are tired of the venum bull sh*t but im not sure if i baught RCs or Venums. are they different in color or something? i got them over the summer and im close to starting the car but now im not sure if i want to yank them if they are vemum or what. if they are as bad as ppl say them ill take them out. did the law suit go through or what. i would like a refund to pay for new ones but that prob wont happen. any advice would be helpful thanks.
o and please just dont say "take them the
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Really? I bought a (used) set of the PTEs, and I thought that they were 550s. They seem to match well with my Lexus AFM (Which I don't have the long adjuster screw for) so maybe...
figgie
and that is the other issue with injectors
are they 550 or 580? Or are they the same?
A lot of companies put the flow at 550cc/min as that is using the 80% duty cycle. Most of the time when you see 580cc/min means they were measured at static open (100% duty cycle) which is never a good situation to be in.
The buyer must read how the company (I know RC uses 80% duty cycle) measures thier injectors. Either 75%, 80% or 100% DC.
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
I went with the 550's off the early rx-7 turbo. You know, the low impedence secondaries. I have had nothing but good things from them. I flow tested them before I placed them on the car and since then I never had a problem. I recommend those. But good luck finding a set without paying a lot.
whasian
figgie
whasian
Those are Denso 550. Almost the same like the Bosch 550's. Both are pricey!
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
I dont see why no one likes the venoms, I have been running them for about a year now and have had no problems... (venom 550cc, lexus afm, afpr, etc.)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Search on here about all of the problems everyone has had with them and how many engines have laid down due to them, then you'll understand ;).
Just curious here, do you know your A/F's?
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
whasian
Same ones I am planning on running. Mine are at RC getting cleaned and flow-tested.
