i recently had a bad clutch and it was slipping really bad in every gear, so i got a new clutch from Toyota and i had the flywheel resurfaced. I know when i had the flywheel resurfaced, it was done right. After driving it for about 2000 miles on the clutch, it started slipping in 3rd and 4th... on the new clutch. when i put it in 5th and back in 4th and then 3rd and go WOT, it won't slip. I have noticed that it would only slip when i push the clutch pedal all the way to get it in gear and release the pedal and give it gas,going WOT, it would slip.
my question here is....... Is my Slave Cylinder going bad ? I m planning on replacing this, this week and before i spend anymore money on the car. i want to make sure it's the slave cylinder.
