Old specs.
Bolt on T4/60-1 on a stock ported manifold. Coatings galore. Made about 420rwhp at 18psi, and was happy to be run at 21psi on the street on 91pump gas.
New turbo is Masterpower T-70 (Really a 69.5mm) Hot side is .63AR. Manifold is modified Ebay special. Coated of course
Revised all the IC pipes, and built new 4" ID intake pipe.
PCV system now breathes through Parker filter to trap any oil vapors...
Added some fire sleeve and abrasion wrap in places where the stainless was rubbing on stuff. (Like my AC lines!)
DP is wrapped 3" ID, coated etc.
WG is Ebay special, coated, ported and vented to atmosphere.. TBD if I like that much noise, if not, I'll build in a muffler for it.
Just need to get the MaftPro running and enjoy the car again.
Oil system is same as before, with a full flow Canton filter on the right side, and the bypass OilGuard to the left with the green top and smaller AN lines.
I powdercoated a few more things since last time around too.
