Welding Intercooler Pipes
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Whats up everyone?
I have the DIY intercooler hardpipes from DM (aluminum) for some time now and I feel like changing up the piping layout.
Doing the route I want will call for some welding to avoid having 4 or 5 couplers between the TB and fender.
I've never had anything welded before and I do not have much knowledge about this.
What type of welding do I want on the aluminum pipes and how much do shops charge on average per weld?
Also, I have some pipes cut that are not exactly 100% even...its really not that bad but can it be successfully welded or do both surfaces have to be 100% straight.
Any other relative information on this subject is appreciated.
Thanks
MDCmotorsports
Indy 500
www.MDCmotorsports.com
You'll want a shop that is capable of welding aluminum with a TIG welder.
I would expect 4043 welding rod to be used, but I have seen intercooler pipes made out of 6001-t6, and then I would go with the 5356 rod.
williamb82
907
4
Tampa, Fl.
the cuts need to line up to each other flush. completly flush. trying to fill in a gap on thin aluminum i/c piping would be a huge nightmare and youd be charged alot for it if they could even do it.
just90gs
yortown Va
This is right
