Weirdest Idling Problem...
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
After Reseting the timing for my car it was idling and driving perfect. the next day we gave her a tune up with new spark plugs , wires. after we installed everything back together it was idling very weird. we found that disconnect 3 and 4 plugs from the spark plug, it doesnt respond at all. but the injectors are new....
i got these fallowing codes :
14 Ignition Signal
Diagnosis
No "IGF" signal to ECU "A" times in succession.
A = 6-8 (7M-GE)
A= 3 (7M-GTE)
Trouble Area
Igniter and ignition coil circuit
ECU
21 Oxygen Sensor Signal
Diagnosis
Detection of oxygen sensor deterioration.
Trouble Area
Oxygen sensor circuit
Oxygen sensor
ECU
22 Water Temp Sensor Signal
Diagnosis
Open or short circuit in water temp sensor signal (THW).
Trouble Area
Water temp sensor circuit
Water temp sensor
ECU
24 Intake air Temp Sensor Signal
Diagnosis
Open or short circuit in intake air temp sensor signal (THA).
Trouble Area
Intake air temp sensor circuit
ECU
43 Starter Signal
Diagnosis
No "STA" signal to ECU until engine speed reaches 800RPM with vehicle not moving.
Trouble Area
Ignition switch circuit.
Ignition switch
ECU
52 Knock Sensor Signal
Diagnosis
Open or short circuit in knock sensor signal.
Trouble Area
Knock sensor circuit
Knock sensor
ECU
all together is: 14 21 22 24 43 52
i recorded a video to give an example of my problem. thank you everyone.
http://www.youtube.com/watch?v=i23MeVh9vL4
jdub;1226858 said:
Pull the EFI fuse, drive the car and re-check the codes.
I do what this guy saids to do..............make sure you put the EFI fuse back in first though.......:biglaugh:
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
did you verify the correct installation of the spark plug wires?
Also, clean up that rats nest of wires coming over the top of the engine...at least wrap them in some split loom.
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
i actually undid that the previous owner did a horrible wire job and i wanted to see if anything looked wrong. it all checks out though...
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
im doing that right now.
so i pulled the efi fuse out and it didnt start as i thought. and after i put it back in , drove it a lil . turned it of and back on the on switch and it gave me these codes 14 21 22 43
so 24 and 52 are gone
it still sounds and drives the same.
i press on the gas and it barley wants to move..
vas85
SupraNut
Sep 29, 2006
391
Sydney, AU
Why were the plugs changed if it was working ok?
Have you tried reverting back to how it was and then re-testing?
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
because i just bought the car and of course it needs a tune up
and yes i tried everything. sprak plugs, with new wires. old wires with old spark. new spraks with old wires. everything. same thing...wtf
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
noel;1227709 said:
well lets see new spark plugs and wires ask youself what does the wires connect to ? coil Pack change that and retest ...just my 3cents...
the coil is fine already check read the 1st posting
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
OOPS my B lol so the wires are new plugs and coil pack are good ....i dunno u got me!! if i were u i would start curseing and throw a lil fit punching the wall and stuff!!:aigo: double check your grounds...
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Can you make another video? Surely the helicopter is not still hovering over it. LOL
Mine sounded like that until I fixed both my coil pack, and reset my timing. Check your timing marks. Verify that the timing marks are lined up when the the crank pulley is at "0". Also, verify that you are actually at TDC while it is at "0". Also verify that your cam gears are installed correctly. The dowel pin should be in the center hole, both on the gear and the cam itself. Then reset the CPS once it is all in the correct place, if it is not already there. Once all of that is done use a timing light to put it at 10*BTDC. If the CPS is installed correctly, you should be able to fine tune in both direction.
UpbeatFish
Permanently Banned
Oct 4, 2007
159
Fail town
okay i will do this tomorrow
i just want to say thank you everyone for your help!!!
<333333
johnathan1
Supra =
Aug 19, 2005
5,056
A video really isn't necessary. With all of those trouble codes, you have some major issues. My money is on your wiring harness. I can almost guarantee that is what is causing 95&#37; of your problems.
You probably bumped the brittle old wiring as you were working, and now it's not making contact like it used to...you have a lot of codes that will affect the way the car runs. I would start inspecting the wiring. If the copper wiring is corroded and green (like most supras these days) you really should replace the entire harness.
