Well recently, my car has started running rich and had a rough startup(and getting bad gas mileage).  Well it's been running pretty good, still have the waterfall effect, and the rough idle goes away when the fan kicks in.  Well i went on a 20 mile run and back to a nearby city.  Ran GREAT getting there and on the way back, i start to notice a skip.  I was like ok maybe some bad gas or something.  Then it started skipping really BAD when i started to give it gas.  So i start driving and my car starts to shake violently only when i gave it gas.  So i check gages. Oil pressure and temp fine and voltage as well.  I thouhght it jumped timing so, i pulled over.  The engine purred like a kitten.  revved it, turned off engine, made sure no leaks and made sure spark plugs were good.  Everything good.  Left and it was shuttering as before.  I was almost to the house to drop it off when about a mile away it cleared up and ran fine.  Drove it around the town like nothing had ever happened.  So i check all fluids, clean, no metal, no murky, all looked normal.  WTF happened?
Checked, no codes and no check engine light on.
