Weird oil filter location.
boostin89
59
california
Might be a repost but.. I just did the first oil change with my new supra and that was a weird ass experience. Is it just me , or is the oil filter in the worst possible place? Weirdest oil change ive ever done. Maybe it was my technique, but either way toyota shouldda planned a little better. The filter is lodged between a rock and a hard place (almost literaly), just seeing if anyone else has the same opinion?
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
hah, I had the perfect angle...had the filter wrench on, it had the vulcan death grip on the filter...just no freaking place to turn it. That's after I learned yoga to be able to manuever my arm in there. Filter relocation FTW.
-Derek
boostin89
59
california
Honestly its the worst i've ever had to work on. I'll check out some filter relocate Threads, im sure theres some on SM. Because that is a bitch to do every time i need to change oil.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
That's funny - I just had a bad filter change experience as well, and posted it in the General Discussion section. It can be a pain!!!
SupraMario
I think it was the google
7
The Farm
The NA is easy as hell,
Spark plugs are annoying too. glad you dont have to change those every 3k miles.
aye mate
Hiatus over.
Maryland
Once you get used to the filter placement I don't think its that bad. I always get oil all over myself when I take the filter off though. Oh well, rather a little oil on me than old oil in the Supra.
Supra
304
Rockford, IL
You guys are doing it wrong. :icon_bigg
Look for a cup shaped filter wrench that fits on the end of the filter and grabs the dimple/notches. Once you find the right type of wrench, look for one that has a square in the center to accept a 3/8 rachet. If you like the Fram grip filters or use a filter without notches, find a filter wrench with three fingers that close against the filter. It's a bit harder to use but much easier than brute force.
Oilter wrench -> swivel -> 12" extension -> rachet
With the extension against the X-member, it's *almost* a straight shot from underneath the car. I actually use a wobbly ball-end extension instead of a full swivel.
N
NDBoost
Guest
you guys are just a bunch of pussies. I do oil changes on 115 degree concrete driveways with a hot motor and i just reach my hand up there w/out the car being jacked up btw and take it off.
slide the pan under the plug (car still not jacked up) and undo it. bingo bango done :)
aye mate
Hiatus over.
Maryland
:withstupi
I do that if I am feeling weak ATM.
SupraMario
7
The Farm
I used to be able to do that, and did it for about a year.
then i put TEINs on their and bam, im skinny and i cant get under the car.
shaeff
Kurt is FTMFW x2!!!!
11
Around
i just took off the accordian hose and reached in and grabbed that sucker. it was easy. now that i relocated my filter to near the passenger tow hook, it's even EASIER. :)
-shaeff
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i'm just waitin for my filter to hit a speed bump... but it's like a $10 piece, and if i ever scrape, i'll get out n check, so it doesn't bother me that much, cuz i bet it gets cooled really well down there
