Weird brake problem
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Sometimes when I brake, my passenger front side makes a thumping noise. It doesn't happen all the time, and if I let off and hit the brakes again, it wont do it the second time. The car still stops even when thumping. Any ideas?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
No... It's a thump thump thump until I let off or I stop. It happens about once a second. I'll get Boost Lee to post in here, I took him for a ride yesterday, maybe he can describe it better. I don't think it's a warped rotor because it doesn't happen every time. Sometimes, it wont happen at all. It just started doing it one day, on a normal stop, with no extreme braking any time before it that day. I'd driven it ~50 miles already that day before it happened.
BL said it wasn't a wheel bearing or a rotor problem, but he was out of ideas.
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
It's most definately not a wheel bearing or warped rotor.
The sound...I've never heard before. At least not from the braking system. ;)
The best way to describe it is a rapid but steady paced....knock.
I guess it would be more appropriate to call it a thump, but calling it a knock would more resemble the way it sounds.
It only happened once every few minutes when braking.
I've dealt with brake issues before...But this one is over my head.
-Jeff
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Nope. ABS has been removed. I thought that the first time it happened but one of the previous owners deleted the ABS system
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I'll try that later today and let you know what happens, but wouldn't that cause it on multiple wheels, or all the time, or both?
cuel
1,536
Baytown, Texas
Check the little clips that hold the pads in place. One of them might be worn or broke, letting the pad move up and down.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Could even be a stuck caliper. Mine does that on one side. It makes a nice train wheels on train rails noise when turning at low speeds (1-5 MPH)
SupraMario
I think it was the google
7
The Farm
LOL, Im guessin I had the same problem, mine was a thumping noise on my drivers side. It ended up that one of the bolts holding the whole break caliper on(the top one) had come loose and then fallen completely off. I drove it for like 30mins and when I got home and tried to leave the next day the break assembly actually flipped back and stopped my tire from rotating.
Maybe your sound is different, but I had this and all it was one bolt, 12m 8 grade. auto zone has it for like 40cents.
Jeff Lange
Administrator
4,927
19
Sunnyvale, CA
jefflange.ca
If it was my car, I would remove and inspect the entire brake setup on that side to confirm what it is. Pull the caliper off, check all the bolts and sliders, etc. I'm sure you'll find something not right. Fix and reassemble then bleed.
Visual inspection is your best bet.
OneJArpus
2,798
Agreed!, i had this bad thump when i would go into reverse and then hit the brakes and then once when i was taking off and then stopping. I pulled the wheel off to find out that the lower ball joint had no bolts holding it in place. The shop that worked on my car must of taken them out waiting for me to get into an accident or something (god damn assholes). I would just do what Jeff said. Theres no better way to find out what it is but looking for it visually.
