Weight Reduction for Road Racing
Jiveslug
Los Angeles
Hey all. I am doing some research into my next road racer project and was wondering how much weight can be pulled off of a MKIII Supra NA. Since these are luxury sports cars, I am thinking that a pretty high amount of weight can be shed. Here is what I can do in the race classes I have been looking at:
Gut interior except for dashboard (incl. stereo, paneling, seats, headliner, etc)
Gut doors
Remove AC (but not heater core or ducting)
Remove spare tire, trunk carpet, sound deadening, etc.
Remove all undercoating and tar and junk
Get lightweight aftermarket wheels
Get lightweight radiator and electric fans
Remove all unnecessary electrical gear (power windows, door locks, etc)
Remove TEMS suspension and replace with racing coilovers and adj. dampers (Konis, KYB AGX, or the like)
Things I cannot do:
Replace body panels with lightweight ones
Replace glass
Remove heater core
Relocate battery/get light racing battery
Alter the frame/subframes
Remove the alternator
Lighten any engine parts except to balance/blueprint
Basically, if you are familiar with the SCCA’s Improved Touring rules, you get what I am doing here. Turbos are not allowed, so I cannot make up the power/weight ratio that way. What do you guys think? I am just interested in removing weight at this point, I will worry about adding weight back on with the roll cage and such later. Thanks!
Ryan
CTsupra
Welcome to supramania! Search around, there's tons of info on weight reduction, but not specifically for SCCA rules.
The most you could remove is about 350lbs with out removing the bumper supports and door bars. You also said you can't replace the glass, so make that about 230lbs :D
IMO, it isn't worth it.
figgie
Twin Cities, Minnesot-ah
sell supra
buy Miata or any other light car ;)
Short of gutting the car,
acid dipping the entire body like ford did in the days. No way to lose a significant amount of weight.
Jiveslug
Los Angeles
Thanks Hells. According to the spreadsheet you linked, I can pull approx 525-575lbs. off of the thing. Thats a pretty significant amount of weight. Considering that the MKIII Supra has to weigh 3380lbs as raced in IT, making weight would be pretty easy...
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Jive, Scca is strict on classing though, make sure they'll allow those removals. Replacement seats removed about 50 lbs. (net loss) and I was able to run 235/255 on 17x9/17x10 while losing 20 lbs. over the stock wheels/tires.
Yuo sure about the battery? I run an 11lb. Odyssey one which is allowed in many SCCA solo classes, not sure about IT though.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
Werd I was surprised to see lightweight battery on the can't list.
Lighten any engine parts except to balance/blueprint - Does that include flywheel/driveshaft?
Can't remove the heater core? Is that in the rules?
Replace body panels with lightweight ones - Can't even replace the stock hood?
Yes there is quite a bit of stuff you can remove in our cars but with what you listed you are very limited, and even though I'm a lightweight junkie I'm with CTsupra saying: it isn't worth it. Pick a different car.
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
Since the SCCA won't allow turbo's I wouldnt run a supra, the supra is a Turbo Car it was designed for turbos not some pussy ass NA 6 in it. 3500+ lbs will not do well with a 3.0L inline NA 6
BlackMKIII said:
The dead live! Talk about an old thread!
Kyle: Seriously? That's BS.
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
No, really. Its the street preped class. It wasn't competitive for most of us in that class. There were the big bruisers and then my buddy Eddy with his 88 M3 Me and some swapped Hondas and the such. Its just regulation
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
what suspention mods can you run? if its unlimited, coilovers. oh, get a 4.3 LSD over an open and hack off the passenger side of the dash. you only need one seat (unless you are novice) for auto-x, if you are on a budget run with the passenger seat on the drivers side.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
Hey guys... you do know that this thread is from 2006 right?
