Water leakage
Plau000
135
Tucson
I'm leaking water and antifreeze from under the Intake and head area. Can't really tell its in there somewhere (right before the fire wall). Anyone know where it might be from be4 I go hunting?
Not too bad just take your time and make note of anything you need to remove to get access ie: vacc hoses and wiring.
Good idea to check the hoses at the front of the motor as well as the ones near the CPS suffer in our cars.
RallySoob
Rally Man Sam
Nov 2, 2006
83
Oregon
make sure its the leaking tube 1st before you try to replace it ofcourse...
If it's actually leaking you should be able to spot the leak.
I had one of the tiny hoses under the intake manifold go and it was an easy fix.
overtime I did develop a bad head gasket leak and had no visual signs of external leakage ofcourse, but It did smell sweet all the time. Oil in my coolant and exhaust is white from the burning coolant.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
Whatever bypass hose that is underneath the distributor, sorta behind the cam cover. It blew in half on me... BIG LEAK.
Wasnt hard to replace though. Check it too.
