Water flowing sound inside dash?
Silv89t
57
Fresno
Hey guys on my supra, when start cold in the morning. I can hear water flowing in the center section. Is this normal or is there a way I can fix this problem? I mean I've change the heater core before..let me know, thanks
Silv89t
57
Fresno
So what you mean by burb is, raise the nose of the car up and let the car run while rad cap off? Until there's no more bubble coming out...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
park you car on a steep incline radiator side up high and turn on the engine, let the air get out of the system and add more coolant
mkiii222
Troy, MI
I agree with JJ on this one (he hasn't chimed in yet but I expect he might with everyone saying 'raise the nose'). You do not need to raise the nose to get the air out. If the system is properly closed (ie no leaking hoses) it will 'burp' itself after a couple of warmup/cooldown cycles.
As for the waterfall sound. If you aren't noticing dampness on your floor mats then it's likely a leak elsewhere in the system. Could be any place coolant goes. I've had the water pump gasket and more recently the 90* hose (back of the head on the exhaust side, not half as bad as everyone makes the job out to be). Once the system was sealed back up it stopped making the noise.
