How reliable are the Walbro pumps and how much better is the Denso pump over the Walbro? Can the Denso pump be installed in a MK3 supra??:1zhelp:
chuckmuska2005;1164467 said:How reliable are the Walbro pumps and how much better is the Denso pump over the Walbro? Can the Denso pump be installed in a MK3 supra??:1zhelp:
IJ.;1166361 said:Keep in mind the Denso's have an internal pressure relief valve set at 60psi, this can be problematic as it will relieve at base pressure +boost so ie: 40 psi base + 20 psi boost and it's open and bypassing volume.
Just that volume WILL drop off after 20 Psi boost pressurechuckmuska2005;1166850 said:I understand that base fuel pressure and 20 psi would would cause the relief valve to open but what does this mean exactly. I don't understand the full concept.
And just what "modification" is that?92TealSupra;1166861 said:The Denso will not allow you to go past 60 Psi~ Without some modification.
New 044 and 040's are made in the Czech RepublicGotTurbos?;1166865 said:Another contender is the Bosch 044. Flows more than the walbro and denso, and is reasonably priced.
IJ.;1166889 said:Just that volu,e WILL drop off after 20 Psi boost pressure
I had one of each fail within 2 weeks of installation, neither were ran hard.
Using 2 x AeroMotive Tsunami's now and they've been faultless, If you could find Old stock of the German made Bosch pumps go for it.
IJ.;1166889 said:Just that volume WILL drop off after 20 Psi boost pressure
92TealSupra;1166890 said:You like those Aeromotive Tsunamis? I looked into them, and compared to 'many' that are out there, I would say they're a good quality, along with a good price, I am still figuring if I am going down that path.
GotTurbos?;1166892 said:Wow, I had never heard anything bad about them. I know a couple locals who have run them with no issues. However the same can be said for RPS C/C clutches when that certainly isn't the case
My single walbro feels like its getting to its outer limits at 400hp, so I think I'm going to have to upgrade soon so I can turn the boost up!
IJ.;1166893 said:They're a bit noisy but hold perfect pressure all the way to 22 Psi boost so far.
I have a brand new 300LPM Denso here I pulled out because of this, pity because they're so quiet they're a prefect daily pump.
IJ.;1166897 said:My engine is easily a 1000hp build but I keep it around the 550rwhp as a maximum to get some sort of longevity out of it.
(have a look at the 1st page of my "what I did today" thread for full specs)
