W58 Pilot Bearing
JustAnotherVictim
Ok so I go buy a pilot bearing for the w58 yesterday and it ends up being way too small for the hole in the flywheel.
Do the R154 and w58 use different size pilot bearings? Every place I check only shows one pilot bearing for both. The Tsrm wasn't much help either, I tried searching the epc and apparently they don't use "pilot" but use "bearing" and "clutch" about a million times. :icon_conf
6201-2RSJ that is the bearing number.
chriso
Supranian
Bay Area, CA
Not rubbing it in, just trying to give a 2nd opinion.
If I wanted to rub it in I would laugh when you try and remove the old pilot bearing (if you crank has one), that is a beeeech.:biglaugh:
Oh and now I have to change my avatar.
chriso
Supranian
Bay Area, CA
Hey Rick, forgot to ask, did you ever get those grill pieces and do you need a Toyota badge that goes on them. I found an extra one.
Either use a slide hammer or some Grease and something the same diameter as the hole!
Push the grease in then the rod, tap with a hammer then put some more grease in and repeat!
