W58 help?
mazdamx640
United States
So I have a 88 that i'm swaping a 2jz into and i found a w58 for a great price so I am wondering what I need to make it work its out of a 89 mk3 with a na 7m and comes with driveshaft and flywheel so I know I will need a bellhousing for a 2jz but what about the flywheel will that work with the 2j? and will the tranny mounts from my auto work?
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
You need a bellhousing from an SC300, NA Supra or IS300. Same with the flywheel (has to be from SC or Supra only, IS has a dual mass).
Tranny mount won't work either. I'm running a 7M W58 with a MKIV flywheel, and an IS300 bellhousing.
mazdamx640
United States
I am having trouble finding tranny mounts for the w58. I thought I read somewhere that a mount for a r154 might work or maby I could use a w58 mount from a mk4. Any ideas?
destrux
1,183
10
PA
A MKIV mount isn't even close. You need the trans crossmember from a manual trans MKIII, not just the rubber mount.
You'll also need a different slave cylinder, but I've posted that info at least 5 times already, so if you search you'll find it.
If you don't have luck with the search here, use google. Type this into google to search only this forum....
site:supramania.com then type your search words here
example...
site:supramania.com W58 2JZ swap
