w58 + 7mgte in ma70.....whats needed....
asdfsupra
QLD
Hi as the tiitle suggests i want some info on the what bits and pieces are needed to put a w58 behind the 7mgte....
what bellhousing?
any custom bits?
w58 shifter location once in the ma70?
or is it all just a bolt up affair??
im in Australia and the w58 box i use will either be from a mk4 NA sup or a 2.0tt mk3 sup... i know the mk4 is a better option but i just want the easiest / quickest option....
i appreciate any help...
cheers...
asdfsupra
QLD
lol....
any more info???.....
any 1 done this b4 that can tell me exactly whats needed??
cheers
drunk_medic
7Ms are for Cressidas
Woodstock, GA
I don't think the W58 from a 5-speed Supra would be a good option - I believe it's cable shifted, and the bellhousing pattern would be for that of a 2JZ engine. The W58 and bellhousing from a 5-speed NA Supra [7M-GE] would probably be best.
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
sorry man, here is a site that you may find useful for your swap. Here is a direct quote about the mk3 w58 and the 7mgte Click me
"As far as transmission choices, you can reuse whatever trans your NA had. The W58 (NA 5 speed) will bolt up to the 7M-GTE w/no problems (just use the NA flywheel/clutch assembly). The NA auto trans is basically the same as the turbo auto trans, just some subtle differences in the clutch packs, etc. to hold the extra power. If you do have an auto trans you might want to think about rebuilding it or replacing it w/a 5 speed as it will hold only about 300rwhp. The W58 should hold upwards of 400rwhp and the sky is the limit w/the R154."
drunk_medic
Woodstock, GA
You guys.. you are talking about the W58 from a MkIII Supra.. not a MkIV NA's W58. The reason that the MkIV NA cannot use the same short shifter as the MkII and MkIII's is because it shifts different than these other ones - it's cable shifted, where the others are direct linkage.
Jason T
JZS161 Aristo TT
Auckland New Zealand..Aotearoa
what bellhousing?
any custom bits?
cheers...
I have a 1G Twin turbo 5spd from GA70 MK3 behind my 7MGT using 5mg bell and flywheel redrilled to take heavy duty 1GTT coverplate with standard drive plate cover plate is a 2100 pound and dont slip with my abusive driving
Gearstick need to be the most reward spot (stitting over uni joint Pic #5 )
ABS needs to be retro fitted or removed mine has sensor in dust sheild with gear on yoke
Your speedo will not read corectly change diff to suit or recalibrate
E
Eddie the Eagle
Guest
wat are the plus sides to using the w58 as a posed to the r154? would you get faster acceleration with a 58 or 154?
W58 shifts nicer but isn't as strong as the 154.
Ratios are close enough that I doubt you'd see a difference.
--W58---- R154
1:3.29---- 1:3.30
2:1.89---- 2:1.95
3:1.28---- 3:1.34
4:1.00---- 4:1.00
5:0.78---- 5:0.75
asdfsupra
QLD
and price....especially over here in aus.....r154 is bout 4 times the price of a w58 and bout 10 times as rare....
thanks heaps 4 ur info guys...
cheers
