VSV help needed!
Status
Not open for further replies.
TheMafyoz
24
Pasadena,Ca
hey,
i need some help locating where this VSV bolts on to..i found where the other one mounted but not this one...=/ please help:1zhelp:
thank you all
TheMafyoz
TheMafyoz
24
Pasadena,Ca
jrot;1663547 said:
just delete it. you dont need it anyway.
u mean that it is not important part of the car and i can work my car perfectly without it?
---------- Post added at 05:43 PM ---------- Previous post was at 05:43 PM ----------
89nasupra;1663549 said:
Then why did the engineers at Toyota put them on the car?
OP, it should bolt under the intake near the other one. I have both of mine bolted there. Not sure if it is the right place or not though.
just on top of each-other??
TheMafyoz
24
Pasadena,Ca
89nasupra;1663554 said:
No, the bolt or stud down. the vacuum manifold should have some more out lets on it near the center of the intake. There is a bolt around there you should be able to bolt it to.
the spinning black thing just broke is that fine =/
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
GrimJack;1663570 said:
The spinning black thing is an air filter. It will work without it.
The two VSVs under the intake manifold are for the fuel pressure regulator, at the front, and the EGR, at the back.
but if your have an AFPR and EGT delete..you dont them correct?
You dont have afpr delete. You need the fpr aeromotive or stock.
If you do delete egr then yes you dont need the rear one.
jrot
195
knob noster, MO
i should have been more clear and for that im sorry....i took the front one out and ran manifold line straight to the fpr and it is perfect no miss no idle issue no poor mpg in fact my mpg is better than most....use it if you want but its a useless unneeded part...that little thing is not going to make you lean or rich and its not gonna blow your motor being gone...ide be willing to bet that most have not tried to run it this way...90% of the annoying vac lines are for those vsv's and they did not effect the running of my car at all being gone if not helped it just a bit....ive been doing 100mi a day for a year because i work far from home and its fine.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Do you know what that front VSV does?
jrot
195
knob noster, MO
it does exactly what radiod says it does....a post in a different thread says it vent vapor built up in the fuel rail when coolant is warm. so i guess since ive never had the heat soak issue ive never needed it even on the hottest of summer days in NM and now MO...thats a bit over engineered if you ask me...mine went bad and made my car run like crap so it went away and it ran great, better than ever....i guess if you do have a heat soak issue it might help though i really doubt it....maybe i shouldnt recommend others remove theirs but for me it was the best choice....you dont NEED it but its not a bad idea i guess.....i just cant stand the rats nest of vac. lines in the 7m engine bay so if its not absolutely needed then i delete it....
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
jrot;1663849 said:
yes its a fuel pressure up vac. solenoid valve. as for exact operation i would be lying if i said i knew "exactly" what it does but if i remember correctly from a year ago it was tied in to the vac line that went with the power steering idle speed up valve...i "assume" this is where you tell me this is where the motor gets its 1:1 referance on boost....how ever i dont believe it worked accurately if that is what it does....all i know is our fpr works just fine without it....if it doesnt then prove me wrong and ill put it back...toyota also had to do alot to these cars for epa regs ect....just cause toyota put it there doesnt mean it has to be there to run, or run properly....like i said ive got a year of real world testing and im better off with mine gone.....if radiod is right and it bump fuel pressure on warm starts then big deal it will run rough for a sec on a warm start....ive never had an issue.....if its more important then i actually hope im wrong.
Actually, the point I want to make is different.
You need to understand why something is on the car before you muck with it. You ABSOLUTELY need to understand it before you come here, to the technical section, and post advising other people to muck with it. Toyota is perfectly capable of putting something on the car that isn't required where you use it, however, is critical in some other environment. Furthermore, they are also very capable of adding something to a car that only saves the engine from failing once every 10,000 starts. Or extends the life of the average engine from 40k miles to half a million miles. Your year of real world testing pales to near insignificance by comparison to the testing done by Toyota.
For this particular piece, when was the last time you ran the car on a hot day, shut it off, and tried to start it again 5-10 minutes later? This VSV combats heat soak on hot starts, by allowing higher pressure to the fuel pressure regulator, which will flush hot or boiled fuel out of the fuel rail.
jrot
195
knob noster, MO
understood and point taken....last time i did it was mere months ago when it was 110 degrees hour of driving and a qiuck stop and another hour...had no issues....for me it works fine without it after thousands and thousands of miles....i guess what my original post should have said is for me it works great without it....
jrot
195
knob noster, MO
i cant tell you what toyota's exact reasoning for putting it on was....but under this logic we better stop using different turbos and injectors and anything aftermarket cause toyota didnt put it there....
Status
