VPC/SAFC
drjonez
the motor city
www.4cefed.com
not sure what you're looking for. it has been done....no different than running a VPC+SAFC @ 300 rwhp.
IMNSHO, i think it's retarded. if you're shooting for more than 500 rwhp, get a standalone. the gains from the switch are enough in and of themselves to warrant the switch...
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Not having any problems with the car.. Car runs beautifully; just problems with my FUNDAGe!
VPC = 350
AEM + Tuning = 2700...
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
Im with Dr.J....weve done a VPC/AFC to 630whp (HiPsic car before the AEM) and it was past the point of diminishing returns. Tuneability suffered, and it wasnt very well-mannered. I agree to save up for somethign a little more sophisticated for bigger power.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Hmm...
You are very correct; but until I can save the money.. Lets keep this thread open for once I get my turbo back and get the VPC up and running. I'm sure I'll have some questions about it...
I'm not looking to run the VPC/AFC setup for too long, just long enough for me to save. I catch on to most things fairly quickly so this shouldn't be too hard, there are always just a couple bumps in the road..
drjonez
the motor city
www.4cefed.com
again, i'm unsure where the problem is- VPC->SAFC->ECU. tune it properly w/a WB....and you're done.
if you're only going to be running it for a little while, use your head and don't crank the boost....that won't end well.
drjonez
the motor city
www.4cefed.com
as stated above, you want the SAFC after the ECU because the VPC's output is fairly "dirty".....the SAFC seems to do a good job of cleaning it up.
isnms
United States of America
Oklahoma
i80.photobucket.com
See if this helps. Thank Bondango, he sent it to me in a pm some time back.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
Hmm... This is looking more complicated than the afc/avcr installs..
Where do I get this resister? And then I just cut the two wires and put the resister in the middle, connecting them?
Interesting...
drjonez
the motor city
www.4cefed.com
heh. no more complicated than any other install. the point of that diagram is for someone who doesn't have the VPC wiring harness (it was PnP).
get the resistor @ radio shack.
yup, you can simply cut the 2 wires and solder it in....probably best to do that @ the ECU as well.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
What does it mean by VPC dip settings, as seen on that picture on the right? And yes, the VPC does come with a harness for specific vehicle.. but the one I bought was for an 87-88 and the car it's going into is a late 89~
drjonez
the motor city
www.4cefed.com
the VPC is a generic device, one that can be used in multiple vehicles. its input/output is configured via DIP switches, located inside the case.
since you don't have the proper harness for your car, you'll need to hard wire, as shown above....or source the proper harness.
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
I've been running VPC/AFC for awhile now, I run 1.4bar on the street with no problems. Yes I agree the VPC isn't the greatest piggy back out there, this thing was made in the late 80's early 90's. I will evenually switch to a MaftPro, cause I can't afford an AEM stand alone. But I'll be running the VPC/AFC as long as I can.
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
Disced said:
We have any experts here on running a VPC setup with BIG boost/high HP? I'm talking 600 +...
Those two don't go together. Before you push big boost, you need the supporting mods (and prolly a built engine, depending on how much boost), which will run the price tag up just as high, unless lifespan has no meaning to you.
(Power) divided by (price of that power) equals (wear-and-tear factor)^2
Disced
Pie + NYQuil = FTW
Edmonds, Wa
The motor is fully built... 1mm OS valves; ferrea valve train, JE pistons... ARP and what not.. Maybe you should check my build thread before you comment?
