VPC map sensor 2bar?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I was going through some of my VPC documents when I came across this:
I've run more than 24psi before with my VPC, and had no problems.
The real question is; Where's the limit?
MKIIINA
Destroyer of Turbos
Plano, TX
I've done 20psi through my jt61gt without issue. I thought there was a way to use a GM map sensor if higher boost was required? Or is my mind just wandering again....
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Well, just ran 26psi on mine.
Car ran amazingly smooth.
We installed some new fuel lines, fuel rail, and 680cc injectors.
Running really strong. We're going to dyno the car on July 18, so we'll see.
