Venting the ISC.
Hmong_1G
Name the Place and time.
Dec 31, 2008
280
California
Sup guys. Well I search with no luck. I'm hitting the track soon and fabing up a nice intake pipe for my stocker. I was wondering if I can vent the ISC to the atmosphere without catastrophic damage. I want to eliminate the hose from the intake to the isc if possible ( less fabing).
LMk thanks.
ians13
537
Jacksonville, fl
LMk thanks.
it would be ok to put a small filter on it if you have speed density, but if you’re running a MAF your going to have problems because it's function is to let metered air into the intake manifold, letting unmetered air in will cause a lean condition resulting in erratic idle
shaeff
Kurt is FTMFW x2!!!!
9
Around
Right on. Introducing rogue air will cause all sorts of issues. (think large vacuum leak;))
