I have a few questions I'm hoping someone can help me with. I bought a 90 turbo a month ago. The hg blew so I pulled the engine and picked up a used jdm engine. I ordered the new parts I needed and was going to put the engine in this weekend but...
The exhaust was within spec .08-.012 in the only strange thing was 3 of the lobes appeared to be almost pointed. My real problem however is that when I went to do the intake side I notice both valves on cyl 1 and one valve on cylinders 3,5 were completely stuck open. What's going on? corrosion? I was not going to pull the engine apart at this time (to change to metal hg) because I did not want to void my warranty. I also see a small amount of corrosion (small brown rust spots) on both the cams in the crank case and on the crank. I'm just not sure what to do. try to warranty or just pull the engine apart and go from there? any advice would be appreciated
Thanks in advance
Thanks in advance
