how much vacuume should the boost gauge show for a turbo 7m at idle?
3.0 GT 2JZ Holset Mafia Nov 30, 2008 381 1 0 Franklin, Tn Jan 26, 2009 #1 how much vacuume should the boost gauge show for a turbo 7m at idle?
grimreaper New Member Jul 2, 2008 2,180 0 0 Dallas Jan 27, 2009 #2 most healthy cars are in the 18-21 in/hg^2 cams will lower that vac at idle and many other things as well. good read http://www.cygnusx1.net/Supra/TechTips/vacuum_gauge_readings.aspx
JDMMA70 Active Member Dec 4, 2006 2,550 0 36 Houston Jan 27, 2009 #3 im getting -21mmHg (i guess thats the same as what according to the cygnus page) at idle it seems the norm for most supras ive seen
3.0 GT 2JZ Holset Mafia Nov 30, 2008 381 1 0 Franklin, Tn Jan 27, 2009 #4 JDMMA70;1232947 said: im getting -21mmHg (i guess thats the same as what according to the cygnus page) at idle it seems the norm for most supras ive seen Click to expand... Ok. I was justwondering because my boost gauage is all the way down until boost kicks in and I didn't know what it was supposed to be at.
3.0 GT 2JZ Holset Mafia Nov 30, 2008 381 1 0 Franklin, Tn Jan 27, 2009 #6 grimreaper;1233004 said: stock gauge? Click to expand... Yep
Rennat 5psi...? haha Dec 6, 2005 2,844 0 0 Tracy, CA www.myspace.com Jan 27, 2009 #7 mines -19 on an aftermarket gauge... my stock gauge just stays pegged at the bottom.
mk3tattoos New Member Apr 12, 2008 1,104 0 0 Bremerton, Wa Jan 28, 2009 #8 stock gauge is not very good. you should get yourself an autometer gauge, or any aftermarket gauge. But don't get anything less that an autometer.
S shiftysupra New Member Nov 4, 2008 180 0 0 Tucson, AZ Apr 13, 2009 #9 my tru-boost is usually in the range of -17 ~ -19 under vacuum
shaeff Kurt is FTMFW x2!!!! Staff member Super Moderator Mar 30, 2005 10,592 11 38 Around Apr 13, 2009 #10 My car was pulling 23 in/hg^2 when it was on the road. The stock gauge is fairly accurate, albeit, very slow. If you've increased boost, get an aftermarket gauge.
mkiii222 Member Mar 31, 2005 697 2 16 Troy, MI Apr 13, 2009 #11 18-21 at idle. Stock gauge will stay pegged on low until after boost has set in.
