Vacuum (mmHg) at idle correct?
JDMMA70
2,550
Houston
My father and I just installed my boost gauge today to see what my vacuum was at idle. I tried searching to see what the correct vacuum i should be getting i hope im refering to the right term.
My car seems to float between 10 and 20 after a time it will just sit between 10 and 20 and then do the same thing again.
JDMMA70
2,550
Houston
s383mmber1;1058375 said:
Were do you have it hooked up? Should be directly off the intake manifold.
the line coming out the intake manifold the same line going to the stock boost sending unit
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I believe it's supposed to be 20-21psi at idle and as momentarily high as 25-26psi upon deceleration. There is a link about vacuum readings and how to diagnose with them on supracentrals sig.
