Vacuum Hose Layout for 7MGTE
Status
Not open for further replies.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Re: Vacume Hose Layout for 7MGTE
Ne0z said:
in this picture, do i unbolt EVERY bolt all the way across in order to get it out? and then just leave it like that but with the suprasport block offs in place instead of the whole contraption?
Short and simple version. Yes!
Now for your vacuum hose layout. All I have to say is the layout for the 7MGE Sux! no wonder you were confused. It's way more complex than the 7MGTE. Now I don't have a 7MGE so I can only tell you what I know you can remove. After that we need to get some one who has a N/A engine to tell you if there is any more.
Here is the pic, see if it helps.
Same thing as before. Red are the vacuum lines you can remove and the green is the places to cap. And the blue dots are pieces that you can remove.
Ne0z
200
Burnsville, Minnesota, United States
okay, few things... the orange signifies where one of the lines run... can i just cap it at the source? and also...
the light blue shows what i actually did... i re-routed the hoses to go into eachother to block off vaccuum leaks, is this okay?
Status
