vacum and wiring connector question
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
ok this is a 2 part question
1st off this vacum "tree" is for a 7mgte, i am putting back together a 7mge, and for the life of me, the TSRM dosnt go into detail, but i gather they are 2 different pieces?
and
and for the wiring
what are these connectors for? both next pictures
and
one of those connectors was rigged the wires twisted together not even tapped :nono:
i take it this is the knock sensor?
damn tps connector
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The vacuum "tree" you show with the three branches at the top bolts to the front (of the car) on the side of the intake manifold. There's a smaller second one which mounts below the intake manifold (toward the rear of the engine). The EPC has the best diagrams for use as a reference.
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?Figure=1708&Page=2
With the wires it's easier to identify if you supply the colors of the color coded wires going to each plug.
If you have a general idea which system they connect to it's pretty easy to track them down via the TEWD:
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
haha guess i should have been clear, i know where that vacume tree goes. but i think there is a difference between the ge and gte, im just trying to conferm.
