V-band mani
colpire
71
Pa
Somthin a little different. Lemme know what you think
colpire
71
Pa
the mani is pretty strong. but the intercooler pipe and the dp to the exhaust should do some help. hopefully...lol
Maybe make some sort of a bracket to go from the turbo to the body to hold it up some. Or from the mani to the block. Thats a lot of extended weight on the head studs.
Sir_2jza70
Sock puppet master
May 10, 2005
53
Canberra, Australia
I suggest a flex joint in the main pipe from the runners to the turbo, then a bracket from the turbo to the body. Some heat wrap/coating would be a good idea too, keeping the heat inside the manifold pre-turbo keeps the pressure up, which might be an issue on such a large manifold.
Its a similar setup to alot of single turbo V8 designs. Should work well.
te72
Classifieds Moderator
6,623
9
WHYoming
The only issues I would take with it are the location of the downpipe routing being RIGHT by the radiator (not the best place for some of the hottest temps under the hood, ya know?), and the lack of space for an air filter. Other than that, it's neat. :)
colpire
71
Pa
yea Im going to run just a screen for the turbo. At the placement its at It'll be hard for something to fly up into it.
And I am curious to see how they will do the dp. It should be interesting. It will definitely be a close fit.
