usdm 2jz?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
probably at junkyards. i've never come across a site advertising a 2j from here.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
2jzge or gte? fat chance you'll find a GTE plenty of GE's though. any reason youd want a usdm one vs a jdm one? i
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
Maybe usdm twins, R sump, getrag.. Still cheaper to convert the aristo motor though AFAIK.
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
lol exactly....but i wouldnt want a 6 speed, there way too much work/money to fit. But i just found this one http://www.japanmotorimport.com/JDM_engine/Toyota/47/2JZGTTE_95-97 and whats up with it? Is it from a supra? Is it imported from japan? Im asking this because i thought the jdm 2jz's had only 280hp and this says 320hp which is the same as a us???
Clip
Oct 16, 2005
2,738
9
Virginia
edmunds specs say that the usdm is 320 hp, i think the jdm is also 280. iirc the 1jz had 280, limited by something (law?), might have been the case with the jdm 2j
SupraMario
I think it was the google
The Farm
the USDM twins are 320 because they didn't have the gentlemen's agreement. In japan the 2jz is said to have only 280 hp because of this.
tissimo
Stock is boring :(
Melbourne, FL
My buddy is selling his out of his 94tt6spd car. Going with a built engine.
gte block/head 58k miles
stock bottom end
head stock besides hks 272 cams, titan cam gears (1k miles on cams/gears)
new head gasket
includes water pump
will not include sensors or nuts/bolts associated with reassembly
Pics show exactly what you get except flywheel/thermostat
driven between 10-18psi, only opened up to 30psi on dyno.
2500
