UPDATED 3/9/2009...87 Supra Build "Jessica"
cmdeoro
VRROOOMMM!!!!!!.....PSSH!
Jan 21, 2009
103
Miami
Hey guys, My name is Carlos and this is going to be my supra build thread. I bought an 87 NA that the previous owner dropped a 7M GTE in it but left the W58 transmission. I bought the car for 1000.00 dollars. But as you can see below the car is in great shape. The only thing wrong is that the cars swap is incomplete. It is missing the harness, ECU, and incooler with piping, etc..
My goal is to make this a weekend/drag car. Around 600 whp will keep me content:naughty:. In order to get there this is what I need. Let me know if I am missing something?
ENGINE:
Clevite Bearings
ARP Main Studs
Eagle Rods
Probe 0.040 Oversized pistons
Probe Piston Rings
Cometic 1.2 mm MHG
ARP Head Studs
Complete Head rebuilt w/ original parts. (Machine shop, and valve stem seals)
Aem Cam gears
FUEL:
Walbros 255 Fuel Pump
Aeromotive Fuel Pressure Regulator
RC 550 fuel injectors
TURBO:
COMP Turbo T04e 61 trim w/ ball bearings
HKS SSQ BOV
Turbo Headers
Godspeed Intercooler with 3" Piping
3 inch Mandrel bent Straight pipes
Undecided Muffler
Some sort of waste gate
COOLING:
Fluidyne or equivilent Radiator
Flex-a-lite Duel Electric Fans
TRANSMISSION:
R154
R154 rebuilt kit
ACT Stage 3 6 puck Clutch w/ 3000 lb. Pressure plate
MC Short Shifter
Polyurethane Transmission Mount
1 pc Aluminum Drive shaft
11.5 pound Fidanza Flywheel
R154 Slave cylinder
R154 Crossmember
I will be keeping you guys posted with pics and so on as I progress.
cmdeoro
Jan 21, 2009
103
Miami
^^Thanks a lot man.^^
UPDATE:
I just got my new harness and ECU the other day. I am going to clean it up and reloom the harness. I will be taking before and after pictures. I also got my turbo manifold in. It has a t4 flange so time for a new turbo.
Next week I will be picking up my R154 Transmission. ARP studs and MHG. WOOT!!!
PICS COMING SOON!!!
jugodegolf
Phoenix,AZ, United States
hvyman;1243258 said:
id stay away from the electric fans as the stock fans do a much better job. get some arp flywheel bolts too and use locktite. the n/a diff is a open diff and you want a lsd. so look for a good used one or buy a beat one and rebuild it. take a look at this page for the rear end:
http://www.supraforums.com/forum/showthread.php?t=430339
good luck with your build.
I had them and they didn't do the job, also heard about a couple fires so back to stock and no problems.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
If you use shitty fans, yeah they wont work well but a good pair with a proper shroud with cool very well with a good radiator.. There is more to it then just the fans...As for fires, thats just poor wiring...
And some N/A cars had an LSD... If it had TEMS, then it had an LSD. Chances are though that your car didn't or doesn't have a LSD.
cmdeoro
Jan 21, 2009
103
Miami
Just found out that the guy that was selling me the transmission already sold it to me. Whatever.... I'm still in the market then.
cmdeoro
Jan 21, 2009
103
Miami
UPDATE!!: Well, I have finally received the following parts
- Greddy Timing Belt
- ARP head bolts
- Cometic head gaskets
- ARP main bolts
- Clevite bearings
- Full gasket kit
I have ordered Eagle Rods and Probe Pistons.
I will be removing the engine from the car in like 2 weeks. Simple because I will be at a cruise this weekend. I will have plenty of pictures by that time.
cmdeoro
Jan 21, 2009
103
Miami
UPDATE!!!
Alright, well I havent been able to take pictures of the parts yet but I will. I do have pictures of me pulling the motor and transmission out. Here you go enjoy.
And of course the victory picture. Me and the heart of the beast.
Now... I will be taking it apart and rebuilding it. When I recieve all the parts the rotating assembly will be balanced.
I already recieved...
Greddy Timing Belt
ARP Head Studs
Cometic Head Gasket
ARP Main Studs
Clevite Bearings
Full Gasket Kit
On the way...
New Oil pan
Probe Pistons 84mm
Eagle Rods
mrchomponthis
GG
basically exactly what my internals are looking like. I would not forget to put in a new oil pump and relocate your oil filter and the oil pump hose from DM just to give yourself some insurance on the oiling end of things.
cmdeoro
Jan 21, 2009
103
Miami
Thanks for the tip but I was actually looking into that. I've just been debating if I should get a new pump. I think I am just gonna do it though.
sirgeorgee;1262542 said:
Very nice car for this price...
Good to see you saving another one
How is the body?Do you have any rust?
Keep up the good work I will keep my eye on this
My build thread: http://www.supramania.com/forums/showthread.php?t=75125&highlight=sirgeorgee's+beast
Thanks, and the car has rust in the hatch area but by the spoiler. Its not to bad though. I have a rust spot less than a 1/2 inch wide on the roff but thats it.
By the way i subscribed to your build thread as well.
cmdeoro
Jan 21, 2009
103
Miami
UPDATE!!!
This weekend I started taking my motor apart. I took plenty of pictures. I also learned a bit about my motor. First off it was recently rebuilt. It had new gaskets everywhere. I found ARP studs but with the paper head gasket. The motor also suffered from a Blown Head gasket. I could tell because all the piston heads where carbonated with the exception of one. So I am gonna go ahead and Assume that the the head gasket was leaking coolant into that cylinder. Here are the pics....
I heard nightmares of the crankpulley bolt. Snap-on tools took it right off.
This is all the buckets of parts I had after disassembly.
This is my boys garage... This is where it all went down.
Now that I have everything apart I can sell some parts. And when My pistons and rods finally get here I will send them out with my block to get bored and balanced...
Now I just have to wait.
cmdeoro
Jan 21, 2009
103
Miami
So I have decided that I am gonna go FFIM. I just dont know which one yet.
Ohh. and i must say I HATE waiting for parts!!! The anticipation is killing me!!!
cmdeoro
Jan 21, 2009
103
Miami
UPDATE!!!
Ok, so I ran into a bit of a problem. I have to put the project on a momentary pause because of some problems I am having with my license. So, with that being said I am going to be selling the 7m and all the parts that I have purchased for it. So I will be posting up a sale thread of it soon.
This does not mean that the project is over though. This just mean sthat when things get better I am going to go with a 2jz w/ a T70.
I will be keeping you guys posted on what is going on.
I am also trying to start a business selling rims and tires. So this is slowing down the build.
Thanks for looking!
AND NO IM NOT SELLING THE CAR!!! ITS IN TO GREAT OF SHAPE FOR THAT.
