underbody Engine Covers
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Better cooling, reduces turbulence beneath the car at higher speeds (see: more stable and save gas)
5
No, the main reason they put em on is to stop water from slashing up on the belts (why it's usually called a slash guard).
My car didn't have one when I got it, and as the cooling system on mine is overkill for my mods at this time it's down the list of things to buy...
CRE
Oct 24, 2005
3,485
Denver, CO
If you've got it, keep it. Mine needed a couple fender washers and I added a couple aluminum braces to firm it up. Splash guard or not, my car feels a lot more stable with it when driving at speeds in the three digits.
5
The small front ones funnel air into the IC and oil cooler...
The main bottom one is the one I'm missing. Usually if they're "falling apart" it's the bolt holes. Just use large washers to keep em on.
CRE
Oct 24, 2005
3,485
Denver, CO
The large one is a part of the forward funnel. Without it the grill opens and air can dump out the bottom.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Makes a significant difference in coolant temps...about 10 deg C lower with the undertray ;)
Give Jeff at Champion (Jay Marks) Toyota a call...best pricing I've seen on one.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i still have mine.. they just arent installed :) i removed the main oen and the one under the foglights. mainly because of my mods they wont fit anymore :( but i plan on incorperating something to help.. like a diffuser
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
After I get a new front bumper and time I'm going to make one out of sheet metal or maybe carbon fiber.... Still about a year out until this happens though.
tlo86
Jul 24, 2005
3,914
Colorado
anything works, ive seen some killer time attack cars use wood :biglaugh: i will prolly use carbon sheets
Amontgomery
not so sad 10psi
Apr 1, 2008
166
Cleveland, MS
I would love to have the entire bottom of my car covered in either flat carbon or aluminum. It adds downforce to the car as well as increasing the cooling that was mentioned above.
8,897
It is not a splash guard. Well, it is, that is not the main purpose. It is as CRE pointed out, for airflow. It creates a low pressure area behind the fan, so you can cool better.
ZoomZoomZoom
On the road again..
Dec 9, 2007
443
KY
I often see engines without fan shrouds. I thought this would also play a significant role in cooling the engine..? I know in computers, its not good to run one with the case open. The fans cannot move the air properly.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Post #9 ;)
Justin
Speakers?
Spokane, Wa
Another thing I noticed about them.
They keep the engine alot cleaner! You don't have shit splashing up from puddles and what not.
*shrug* I have one from a parts car I acquired, I'm going to try and fit it on :)
kingsupra
106
d-town,colorado
my mom threw mine out because it was soaked in coolant. i just hate how hard it is to work under your car sometimes. has anyone used a different set up to still have the cooling effect but it doesn't cover the whole bottom of the car?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Does anyone have a pic of the under tray, I have never seen one. If it aids cooling then I may just have to make one out of abs or stainless.
