Ugh.. getting power to the amp?
Doward
4,245
Alachua, FL
Where have you guys run your power cables, to get them from the battery, to the back of the car (assuming you're still running the battery up front :D)
On my Camaro, I just ran it along the fender, where it meets the hood, up and down into door/windshield area, and then down under the driver's side sill panel, to the back of the car.
Unfortunately, Toyota's better engineering has all kinds of conduits under the carpet/sill area, and I'm having to really squeeze this 4 gauge wire in there.
It seems to be going smoothly so far, but I was wondering how some of you guys have run your power/ground wiring?
Doward
4,245
Alachua, FL
Just some progress on what I'm doing:
My Autozone power antenna :D
Ripping it all apart....
Infinity Kappa's!
Powered by this... 50x4 @ 4ohms RMS
Not bad for.. uh... about $120 total, with 6.5" pods!
*edit*
DOH - didn't realize the pics weren't loading!
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
I poked a hole though the boot for the eng. harness to ecu, and went down to the kick panel. Then, i removed the door sile trim and tucked the wire under the carpet. After that i went under the rear seats to the rear cargo area and hooked the amp up.
