The issue is that I keep throwing code 31 for AFM Signal. First time around I found a used one, put it in and it ran well for two months. Then at the end of February it did the same thing. The car hasn't moved since. What happens with the car when it throws the code is that it will pin rich on idle (10.0 AFR) and it's really difficult to accelerate as the engine starts to hesitate strongly under accel.
Another thing, during Xmas which was around the first time this happened, I found this on the compressor side of the turbocharger:
So I cleaned it up, kept an eye on it and ran the other AFM. Two months go by and guess what... Same oil/grime inside my turbocharger. I'm not burning oil at all.
I figured the turbo was getting too much oil so I bought a restrictor for it however I'm having the hardest time getting these threads to match up.
I wanted to post on here before I wasted more time trying to figure out a way to get this restrictor to fit with other fittings to see if that was sound logic.
Turbo gets too much oil - spews out of the front - coats AFM on idle - ruins AFM.
Possible? Or not very likely?
Or is it that the turbo is just bad.
Thanks guys!
-Nick-
Thanks guys!
-Nick-
