Twin Turbo oil Tube in the way of BIC pre 89 Motor mount brackets! HELP!
SupraMario
I think it was the google
The Farm
Ok, so yea I'm making an ass load of threads. So here it is. Can I bend it back and just get a longer hose? OR? I just would think that bending it back toward the transmission would not be a wise Idea! And bending it down would put it in the way of the exhaust brace...So I'm stuck >< Need help!
So any suggestions?
SupraMario
The Farm
LOL, well if you look there is 4 holes they are the mounting points for the motor mount brackets...If you look below them there is a tube, a black pipe, that is the oil tube for the turbos, it is in the way BIG time. Clear now? or still ????
SupraMario
The Farm
IJ.;1099510 said:
Like I said I can't tell shit from the pics ;)
Oil supply or drain?
I don't think they are supply..the TSRM just calls them the No.2 Turbo Oil Pipe. Nothing more nothing less...
SupraMario
The Farm
IJ.;1099516 said:
If they're drains the main thing to keep in mind is they MUST go downhill at all times.
Have to PM'd Randy to see how he handles this?
I did, I pmed, Jose, Randy and Aaron >< you just got to be the lucky winner of being online and in aussie land :biglaugh:
Water hoses...I'm fine with bending them, anything oil wise with the turbos...umm no.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
easy fix to this situation
go single
i had the same problem on my motor (chaser 1JZ), id just say get a propane torch, heat them, and bend them till they fit
SupraMario
The Farm
go single
Easy yes...Cheap no...and I want twin turbos for now.
Bending them is looking like my only solution...
IJ.;1099520 said:
LOL lucky lucky me
(so I was 4th choice.......)
Actually you where #1 but don't tell the others that. :p
SupraMario
The Farm
soapra;1099804 said:
The brackets fit. no need to bend anything. the lines come close to the brackets but it's not a big deal.
Nope, the bracket will not mount on this unless I either bend it or push it down and mount it. That metal tube is right there.
foreverpsycotic;1099830 said:
Slip the bracket between the line and the block, it will rest on the top IIRC.
So stick it under the oil tube then...hmm gonna try that.
NecroCyde
Lurk R
Calgary/Brooks, Alberta Canada
i used bic mounts, just bend the mounting tab out of the way, the pipe will tuck up nice and snug next to the bracket itself. it will fit for certain so you dont need to have all the mounting points on the oil tube as the one in the first picture would be a bitch to undo in the car, that oil line isnt going anywhere so just fiddle with it until it goes on.
becauseican
Vancouver
www.bicperformance.com
What engine are you using?, is it going into a mk3 Supra?, front, rear, mid sump?. These brackets are for Supra 1jz engines with the mid sump oil pan, other 1jz have different oil pans and different turbo drain lines which wont fit with the brackets. If you have a differnt engine/ oil lines just bend the lines until they fit. If the brackets are genuine BIC brackets the bolt holes WILL line up, I have sold many, many, many sets of these brackets with no problems.
Some clear pics would help too ;)
Randy
SupraMario
The Farm
Randy
Doh, I'm stupid and automatically thought everyone would know. LOL
its a 2jzgte, yes, mid/rear sump. The bolts line up great, I was just worried that it would damage something, but all is good now. thanks for all the help guys.
D34DC311;1099591 said:
naa old aussie men are my type.:biglaugh:
LMAO that is just so wrong on so many levels dude :D
(I've noticed the Gay is strong with the Mk3 crowd there was LOTS of Gay joking at the dyno day yesterday)
Randy is the man to listen to on this one!
(always helps when you have direct access to the designer)
