twin fuel rail 7mgte
24vtoy
76
durban
hi guys
has this ever been attempted
Twin feed fuel rail for the 7mgte
ive got 2 sets of 440cc injectors so im trying to figure out how i can use them :icon_razz
Devin LeBlanc
1,830
Las Vegas NV.
I think you would burn up the stock ECU injector outputs anyways running dual coils of each of them. Unless you are stand alone and have an ability to run 8 injector circuits I wouldn't recommend doing it
If your needing that much fuel should already have a standalone.
I wouldn't pay more than 40$ a set either.
ThAts what I would pay. If they were cleaned and flow tested 60-70.
But there 19-25 year old stock injectors so...
Also you can domestic 80/lb injectors from pre for like 360$. Much cheaper safer way of going about things.
You could use either Mosfets, Solid State relays or even Ign igniters to run the 2nd bath but the fact still remains if you lose an injector you have built a blowtorch....
There's a reason AIC's went the way of the Dodo, these days large injectors are cheap and reliable so there's no reason to run duals.
Devin LeBlanc
1,830
Las Vegas NV.
Yeah that could be done, Just half the people would not go through the trouble of doing so, they would probably just parallel off the harness and end up frying something.
Hvyman, Ill be using 780CC injectors on a stock ECU.
Never said you couldn't. Your also using e85 which needs a lot more fuel for the same hp.
If I was you I would be investing into some kind of standalone to make better use if the fuel. Stock ecu is the limiting factor in your setup.
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
My Dodo Device is in the shed waiting for incorporation into my build... someday... maybe...
...and yes, I am old, not extinct, but working on it SLOWLY... and perhaps a bit "odd" so it's all okay.:biglaugh:
(Someone has to carry the torch for the yesteryear yahoo's among us!;))
-crisp
suprarich
Guest
Nov 9, 2005
2,187
ohio
We use a dual fuel rail and dual set of injectors on the Malta dragster as a staged set up. 861 cc on the primary rail and 1200c on the secondary rail. Not really needed for a street car.
crisp
May 25, 2007
1,785
Ohio
Fuel volume in EXCESS of many engine displacements! THAT's a LOT of fuel, Rich!:aigo:
-crisp
Blackdawg
Taco Soup..my rides
Oct 12, 2010
247
Wyoming
wow...holy fuel..
bioskyline
1,236
powell river bc
found pic!
oddly enough it is for sale here on the fourms.... http://www.supramania.com/forums/sh...e-ported-head-gm-trans-adaptor-etc..-for-sale.
