turning up the idle
willfish
been here since 2003
Apr 23, 2005
648
Pittsburgh, Pa.
I know i this is going to sound terrible, but where do I turn up the idle at ??
diagrams/ pics would be better for me to understad
Will
shaeff
Kurt is FTMFW x2!!!!
11
Around
if your idle is off, something's wrong. you shouldnt have to adjust it. is it idling too high, or too low? check the codes and see if you get anything there. other than that, i'd bet its either the TPS or the ISC.
nice to see you back, will.
-shaeff
willfish
Apr 23, 2005
648
Pittsburgh, Pa.
Dam you Shaeff , TPS , ISC ..... i'm a little on the dumb side, or alittle on the white russian/ nattie light side :hs:
I will be bringing out the ride in a few days from storage because of winter. As I remember the idle seemed low....... so i thought it just needed turned up ....... but TPS an ISC ?????? dam I feel like i'm 16 again...... not knowing what that is...........
thanks for the warm welcome Shaeff :icon_wink
Will
P
PunaMKlll
Guest
TPS: throttle position sensor
ISC: idle speed control
SupraMario
I think it was the google
The Farm
^^ what is that called in the english laguage, its not abreviations, what is it called.
isnms
United States of America
Oklahoma
i80.photobucket.com
check all your vacuum lines
they are right. If idle is off, something is wrong.
TPS, ICS, COLD START INJECTOR, TEMP SENSOR, WIRING......
the list goes on. post some more details, codes, when you get to check it over.
