turbo
91 1jz
64
branson mo
I was thinking about putting a boost control knob on my supra and was wondering wht the highest psi setting i could put it at safely
Raise the boost till you hit fuel cut then back it off till you don't.
If you have a fcd or bcc then around 13-14psi. 17 id suggest having 440's.
Also this will greatly reduce the life span of the stock turbos but it's more reason to go single.
91 1jz
64
branson mo
I was thinking about setting it at 10 psi and leaving it thats prob not too much more boost it comrs 4-7 psi stock
