Turbo automatic trans, who can't shift
peer648
49
Québec
The automatic trans from my 87 supra 7mgte, can't shift itself. I got to shift it myself and the transmission work pretty well. But the overdrive don't work. So what do you think the problem is ? and what about the cost of this repair. Thank you
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
sounds like a valvebody problem, but could also be a controller issue. used trannies are pretty cheap(3-500$) on ebay and the forums. pull the codes, check the fluid levels/condition. go from there
the tsrm is your friend!
peer648
49
Québec
Ok thanks for the TSRM link. It will help me! I'm going MT as soon as i get a one piece driveshaft that would fit. So I don't know what i'm going to do with the AT. Sold it as broken(or little repair), let it in the back of my garage or maybe repair it someday.
ct26fan
4
phoenix
I had similar issue after my car sat for a while. I Found that the problem I was having was corrosion in the connectors to the transmission. A little electronics parts cleaner fixed the problem.
