Tuning with race gas
survyor2
171
West Palm Beach, Florida, United States
I searched this topic because I thought this would have been a topic covered many times but I'm not having much luck. And the information that I do find is conflicting.
On 93 oct: 7mgte, 440rwhp, 18psi, lexus afm, 550cc, .70 a/r SP61 turbo i shoot for 11.7afr at max psi.
I'm on 110oct leaded now.
What psi is my safe max psi? 24-25?
What afr should I shoot for? I've read: same as 93oct, then 12.0, 12.2, 12.5. I want to get this right.
Thanks,
Dennis
I've never heard of anyone on a boosted car shooting for 12.5... When I use race gas, I still shoot for mid elevens and I ran 24psi on 110 with no problems. I don't know of any set boost levels per octane though since different turbos put out different amounts of air.
Disclaimer: I'm not very smart and I don't pretend to be. This is just what I've done in the past. Good luck.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Understatement of the year ^
Funny stuff Jay....at least you are humble.
Thanks for making me laugh!
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Thanks,
Dennis
First off it will be difficult to get to 24psi on a lex afm and 550s.
survyor2
171
I tuned with the 110oct today and here is what I found out.
I hit fuel cut at 24 psi. I backed it off to 23.5 psi and didn't have any issues.
Most of what I read told me to tune for 12.2-12.5 afr. I made an executive decision and set a goal for 12.3 afr while monitoring egts. My max egt is actual 5 degrees cooler at 12.3afr at 23.5psi on 110oct than 11.7afr at 18.5 psi on 93oct.
I was thinking of going with the FCD i have but its not worth it for an extra 1.5psi.
I think I could have run even leaner but I can't control my timing. So there you have it...lower egt with +5psi on race gas. Dyno next weekend to see what I picked up. Maybe I'll hit 500rwhp.
Dennis
Dennis: Biggest benefit with good fuel is knock resistance, this will allow either more boost or more timing or a combination of both if you run out of boost room like you have.
I'd tune to the first signs of rattle on the electric ears then back it down 2 degrees and 2psi to keep it safe Dennis.
Every combination is different there's no xx psi for xx octane.
