Tuning has begun
May 31, 2005
111
Omaha
Alrighty everyone, today it is 75 degrees and low humidity. I spent about 2.5 hours tuning with the afc2 and the plxm300. I definately found out something interesting....
Our ECU is smart. The stock ecu WILL curve it's on fuel under closed loop. Now, I am sure many of you know that already, but I wish I did before I spent 1 hour tuning the low throttle to 12.5 all the way to 4K!! Sure enough, I turned the car off to get gas....turned it back on, and WHAMMY...back at 14.0-14.5 the whole drive home. I am thinking...HMM...that is weird (I checked and all of my fuel % values that I plugged in were still there)...so I test it.... I begin to change the % at idle and get it to about 12.3 and I let it sit...sure enough....after about 10 minutes into it, it had worked its way back to its 14.0-14.5 ratio on it's own. The ECU changed it back to it's on curve. SOOO...at that point, I just set all RPM A/F % to zero across the whole LOW throttle board from 1000-7600. I focused on the HIGH throttle at that point. I do believe that somewhere around 75% throttle is when the ECU goes to open loop, therefore, providing me with my window to actually tune MY values in. I did notice that under 100% throttle between 2800 and 4000 it liked to spike a little lean, so I added fuel. About 5% at 2800 and 3% at 3400. Below are the other values:
4K: -11%
4600: -12%
5200: -14%
5800: -16%
6400: -20%
7000: -20%
7600: -20%
With these values, I have consistant AF's of about 11.8-12.7 Pull after pull on the street. I have yet to get to the dyno. I am going to try and refine these even a little more, but I definately feel a nice power gain, especially between 5k and 7k. These numbers are with the mods listed below on the stock twins at 13-14psi. DAMN, i wish i wasn't so stupid about trying to tune the low throttle...oh well...this is my first real tuning experience on the afc2 and on the 1jz period.
Trev
Dew511
Q-boro, NY
Yeah... I think that 14lbs is the max b4 the ceramic blades feel like they wanna fall apart! Not that I know or anything. Im still running a safe 12lbs :icon_bigg
I
itr206
Guest
blah. The twins really start to wake up past 1bar :icon_bigg
Dew511
Q-boro, NY
You think so...? Im too scared to go past 1 bar. Well atleast until I get a replacement lined up then Ima blow the stock twins :evil2: . Big single or better twins or something comin. This is my only car so I'd' rather be safe than sorry.
May 31, 2005
111
Omaha
Yeah, they wake up alrighty..wake up and die right. it won;t be long:)
Trev
I
itr206
Guest
See Idont care if mine blow. I have all my single stuff just waiting to go on.
I think they will handle it though.
There are a few people that have run like 18psi thru them and stilll living.
Sucks its your only car. I would be to scared to keep a Supra as an only car, they break too damn much. lol
May 31, 2005
111
Omaha
:agreed:
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
I've been running at 1.1bar for the last 6 months now and it's still going.
Daily driven and running 80% of the week at 120mph. "GO 1JZ"
I'm tired of waiting for this turbos to go so I can start upgrading.
Hey Trev is urs still stock turbos?
Dew511
Q-boro, NY
Your so right! So I have to baby her... for now.
