tried to retorque my head
Status
Not open for further replies.
malloynx
NC
well today in the windy cold i tried to retorque my ARP studs. i still don't know if i have a leaking HG cause my tranny is still out of the vehicle. anyway i pull the valve covers and i tried to loose the #1 stud and i broke my 6-inch extension. so i got out my other extension and tried to loosen the stud and i couldn't. i had my torque wrench set to 100ft lbs and all i got was the click. i checked all my studs and they all seem to be tight.
so i wonder, so i still try and crack them loose or just leave them alone??
dbsupra90
toonar
indiucky
shouldnt ever need to retorque studs.
when they are torqued down, it takes quite a bit of force to get them to move. id leave it alone.
if you wanted to know whats up you could always do a leak down test.
stevo86
CT
not commenting about torque your head.. but you shouldn't use your torque wrench as a breaker bar.. if you really wanna retorque, use a half inch drive break bar to lossen the studs, then torque them back down with the wrench. A torque wrench is a fairly delicate tool, even the cold could throw it off, and havin wrong torque readings isn't safe.
Stevo
jetjock
creepy-ass cracka
9,439
You're using a torque wrench to loosen fasteners? Don't do it, there are several things wrong with that starting with it's a precision tool and you can't measure breakaway torque using one. Oops...I see Stevo beat me to it.
figgie
Twin Cities, Minnesot-ah
100 lbs/feet can mean anything. You need to losen ALL the studs and then retighten them down.
Also as stated above do NOT use the torque wrench as a breaker bar!!!
rakkasan
Currahee!!
Fort Campbell, KY
PorterzSupra said:
I know this might sound stupid but umm where are the head bolts!!!??
All Aboard! Welcome to the I-can't-believe-you-said-that express. Next stop, the "cars for sale" section. For your safety, upon arrival at the next stop, exit the train and place a for sale add.
steve_mk3
middletown, NJ
Getting back to the subject-
" i had my torque wrench set to 100ft lbs and all i got was the click. i checked all my studs and they all seem to be tight. "
I think he was checking to make sure they were all tight, not trying to losen them with a torque wrench.
I think from reading a previous post of yours that you thought you might have the beginnings of a small leak. personally I would perform a leak down test befor I messed with the studs. If I were more convinced and wanted to retorque my studs I would get a 1/2 inch breaker bar and back one off at a time and retorque to the proper spec. I am not sure, is it possible that the studs were installed when it was nice and warm and now that it is cold they have gotten a bit tighter. That might explain why so much force is needed to back them out. Again, I am not sure about that, just geussing.
Steve
Status
