Transmission thread size?
carter
"The Ninja"
Nov 1, 2005
743
Ohio
I need to get the motor on a engine stand but the transmission bolts i had wasn't long enough to make it through the stand and thread into the block.
If someone could help me out real quick it would be amazing.
carter
"The Ninja"
Nov 1, 2005
743
Ohio
I guess, lol I went to home depot and a couple other pieces and still wouldn't find it. They looked at me like I was retarded which just pissed me off. One guy tried to help me out but he wasn't much help at all.
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
The correct size is M10x1.25x70mm.
I came across this thread because I needed the same bolts for my engine stand and bought the 100mm posted above which was way too long.
So I thought I'd contribute. :)
Depends on the engine stand legs, you want at least 1d thread engagement in the block, 1.5d is better, "d" being thread diameter.
eg: If the leg is 60mm you would buy bolts with 75mm under the head.
Bri7man
Jul 17, 2009
580
Torrance, CA
Whoops... sorry about that. They engaged all the way but yeah, totally depends on legs..
What are the stock length?
