I'm trying to adjust my tps per tsrm and I'm seeing avery very strange pattern..
For clarity I quote JSeaman,
"turn the TPS fully anti clockwise until you get a 1 (for infinite resistance) then slowly turn it back until it 'deflects' i.e. you get a reading of resistance.."
From his guide thread http://www.supramania.com/forums/sh...IDE-Calibrating-TPS-(Throttle-Position-Sensor)
and TSRM
"Gradually turn the sensor clockwise until the ohm meter deflects.."
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=FI&P=103
Here's the issue, with my tps #89452-28030(vertical prongs-vertical plate) resistance is displayed while turned all the way counter clockwise and I get a "1" when turning clockwise.
So being forced to adjust it backwards and securing it where it deflects as I turn it counter clockwise...
No luck, the rpms jump to 1500 then cut to 700 on its own at this setting.
So I happen to have another tps # 89452-14050(horizontal prongs-horizontal plate) and installed the correct horizontal plate for it on the throttle body and same thing as above, deflection occurs backwards.
Been thinking on this for hours and can't come up with any reason why this should be happening...
and TSRM
