ok, i have my daily 87 supra with a 7M-GE, that has been converted to manual, but is still running the auto ECU.
Well the TPS was broken for a while and i decided to fix it by replacing it with another on from a junkyard. SO i came across a 88 that had a clean Throttle-Body with TPS. I bought it and was just going to replace the TPS sensor and i noticed they were different. I compared the 2 sensors and TB's. One TPS and TB had a horizontal sensor and one had a vertical sensor. SO i replaced the whole throttle body knowing the other sensor wouldn't work. It plugged in and worked fine. Revved faster, etc. But now it idles at 1400 rpm instead of my 900 to 1000. I know it is normally supposed to be around 700, but i have 4 degree's of advanced timing, which made it idle up some. Do i have to Re-time My engine or something? The idle reason doesn't really bother me, but when I'm normally driving(with the new TPS) and go to shift, push in the clutch, it holds the throttle for a second, then drops down. I want to fix that! :aigo: ALSO, i know you're not supposed to adjust the idle screw, thats what the TPS is for. Where should the screw Be(how many turns out from being screwed all the way in), maybe if the new TB was tampered with before :]
THanks
THanks
